[fdo-users] Re: Number of geometry types in Oracle FeatureClass
Haris Kurtagic
haris at sl-king.com
Thu Jun 10 07:52:03 EDT 2010
oh, I see now 2 sql's
second one will not work anyhow, first one looks like it should
Haris
On Thu, Jun 10, 2010 at 1:42 PM, Haris Kurtagic <haris at sl-king.com> wrote:
> Hm, from error itself looks like some issue with provider
> but looking into your code sample you used fdo class name instead of
> Oracle table name (execute sql will execute sql exactly as you wrote
> it).
> It looks like, error code doesn't match sample sql you put in email
> sql in email is the one you used it ?
> Haris
> On Thu, Jun 10, 2010 at 1:26 PM, hanko
> <hana.jaborova at spatialtechnology.se> wrote:
>> Hi,
>> A Good advice is worth gold
>> I have already tried use SQL statement command in FDO. I cannot get it work.
>> I would appreciate a working code example.
>> public void SQLQuery()
>> // create the command
>> ISQLCommand sqlCommand =
>> (ISQLCommand)FDOConnection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_SQLCommand);
>> int count = 0;
>> sql = "SELECT COUNT(1) AS CONT FROM MYTABLE t WHERE t.GEOMETRY.sdo_gtype
>> IN (2001,3001,2005,3005)";
>> //or
>> sql = "SELECT COUNT(1) AS CONT FROM KingOra:MYSCHEMA~MYTABLE~GEOMETRY t
>> WHERE t.GEOMETRY.sdo_gtype IN (2001,3001,2005,3005)";
>> sqlCommand.SQLStatement = sql;
>> try
>> count = sqlCommand.ExecuteNonQuery();
>> //ISQLDataReader dataReader = sqlCommand.ExecuteReader();
>> catch (OSGeo.FDO.Common.Exception ex)
>> System.Console.WriteLine(ex.Message +" " + ex.InnerException);
>> Exception: "ora-24374 define not done before fetch or execute and fetch"
>> Cheers
>> Hanko
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Number-of-geometry-types-in-Oracle-FeatureClass-tp5161882p5162697.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
