[fdo-users] SDE FDO questions
Brad Nesom
kidsmake6 at msn.com
Thu Jun 17 17:26:20 EDT 2010
This sounds familiar to me. I have been combing my memory banks and haven't
come up with anything yet. for some reason it seems to me the problem is on
the sde side. I did find the sql statement to run sql server job. You didn't
say what dbms you are using.
If I find anything or remember what I'm thinking of I'll hit again.
Brad
http://arcscripts.esri.com/details.asp?dbid=15092
On Thu, Jun 17, 2010 at 4:01 PM, Greg Boone <greg.boone at autodesk.com> wrote:
> You should also cc the mapguide-users email list with these questions. You
> may have a better chance at a response there.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] On Behalf Of BTenBroeck
> Sent: Thursday, June 17, 2010 12:43 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] SDE FDO questions
> Hello. I have a few questions regarding the 3.5 provider in MGE 2011.
> When Mapguide first connects, it spawns 3 gsrvr processes on the SDE
> Server.
> Then for every browser session that opens, another one is spawned. AND,
> they
> don't close when the browser closes. The Mapguide service has to be
> recycled.
> Is this normal behavior? If so, is there any way to make the connection
> close when the browser closes, or perhaps set something in the
> serverconfig.ini to shorten the time till it expires naturally?
> We also tried the direct connect method. This is baffling to me, because we
> get the exact same behavior as before. Shouldn't the browser spawn gsrvr
> processes on the Mapguide Server? Not the SDE server?
> Any insight or direction would be greatly appreciated.
> Thanks,
> Bill Ten Broeck
> http://osgeo-org.1803224.n2.nabble.com/SDE-FDO-questions-tp5191734p5191734.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100617/c6e8ef9e/attachment.html
More information about the fdo-users
