[fdo-users] Re: fdo-users Digest, Vol 39, Issue 5
Dassasa Asdasasa borkavulesic at yahoo.com
Tue Mar 9 17:06:15 EST 2010
From: "fdo-users-request at lists.osgeo.org" <fdo-users-request at lists.osgeo.org>
To: fdo-users at lists.osgeo.org
Sent: Tue, March 9, 2010 6:02:22 PM
Subject: fdo-users Digest, Vol 39, Issue 5
Send fdo-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/fdo-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    fdo-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of fdo-users digest..."
Today's Topics:
   1. RE: Re: More funcionallity in Data Table of Autocad Map
      (Martin Morrison)
   2. Re: Re: More funcionallity in Data Table of Autocad Map
      (Brad Nesom)
   3. Re: More funcionallity in Data Table of Autocad Map (brujulas)
   4. AutoCAD MAP 3d 2010 FDO PostGIS 3.4.1 Error Message    "Invalid
      Precision Attribute" (Hermann Karl)
   5. AutoCAD Map 3d 2010 FDO PostGIS 3.4.1 feature class    tables
      are not listed (Hermann Karl)
   6. RE: AutoCAD Map 3d 2010 FDO PostGIS 3.4.1 feature class
      tables are not listed (Greg Boone)
Message: 1
Date: Mon, 8 Mar 2010 12:18:17 -0500
From: Martin Morrison <martin.morrison at edsi.com>
Subject: RE: [fdo-users] Re: More funcionallity in Data Table of
    Autocad Map
To: FDO Users Mail List <fdo-users at lists.osgeo.org>
Message-ID:
    <DF9588AA6E09C04A88DBAC4EBBC7D09D079403E314 at EXCHANGE.corp.edsi.com>
Content-Type: text/plain; charset="us-ascii"
What Dan was trying to say is:  If you select several objects in Map, then right click them, select properties, you can change the values of any of the fields for all of the objects at once.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of brujulas
Sent: Monday, March 08, 2010 11:57 AM
Subject: [fdo-users] Re: More funcionallity in Data Table of Autocad Map
First of all, thank you very much for your answers
I need is a similar tool like Attributes in Arcgis (next image):
http://n2.nabble.com/file/n4696571/Dibujo.jpg
This tool allow a massive change in multiple records.
Any idea with FDO?
Greatings
View this message in context: http://n2.nabble.com/More-funcionallity-in-Data-Table-of-Autocad-Map-tp4692055p4696571.html
Sent from the FDO Users mailing list archive at Nabble.com.
Message: 2
Date: Mon, 8 Mar 2010 11:55:09 -0600
Subject: Re: [fdo-users] Re: More funcionallity in Data Table of
    Autocad Map
Message-ID:
    <5afbfc9a1003080955k4e8a8529q8ea625349de4faf at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
brujulas
  As described by Dan and Romica, I was mistaken. The process would be to
1. Connect the data to map through FDO.
2. Use any number of methods to select the objects desired (pick on the
screen, select in the data view, select through the properties dialog).
3. Then in the properties dialog you can see the feature properties (which
in the case of shape file will be the attribtes of the feature/s). When more
than one objects are selected there will be "VARIES" in the value. Any
change to these values will apply to all selected features.
4. After changes are made you need to "check in" the features in the data
layer you have selected.
Brad
On Mon, Mar 8, 2010 at 10:56 AM, brujulas <gis at cadmax.es> wrote:
> Hi,
> Any idea with FDO?
> Greatings
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100308/74714523/attachment-0001.html
Message: 3
Date: Tue, 9 Mar 2010 01:09:57 -0800 (PST)
    Map
Message-ID: <1268125797116-4700971.post at n2.nabble.com>
Content-Type: text/plain; charset=us-ascii
Thank you very much everyone for the explanation, I'll use the procedure
proposed
Greetings
View this message in context: http://n2.nabble.com/More-funcionallity-in-Data-Table-of-Autocad-Map-tp4692055p4700971.html
Message: 4
Date: Tue, 9 Mar 2010 13:00:47 +0100
Subject: [fdo-users] AutoCAD MAP 3d 2010 FDO PostGIS 3.4.1 Error
    Message    "Invalid Precision Attribute"
To: <fdo-users at lists.osgeo.org>
Message-ID:
    <4F41AEDA278A4447884C61C3AD9A495C01817E87 at rh40.dornbirn.at>
Dear List,
Schema editing with the Schema Editor in AutoCAD Map 3d 2010
is not possible.
If i try to edit the Schema of an connected PostGIS Database I always
get the
error message "Invalid Precision Attribute".
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100309/3b61973d/attachment-0001.html
Message: 5
Date: Tue, 9 Mar 2010 13:18:58 +0100
Subject: [fdo-users] AutoCAD Map 3d 2010 FDO PostGIS 3.4.1 feature
    class    tables are not listed
Message-ID:
    <4F41AEDA278A4447884C61C3AD9A495C01817E88 at rh40.dornbirn.at>
Dear List,
If you connect to a PostGIS database from AutoCAD Map 3d 2010 with FDO
PostGIS 3.4.1
Feature Class Tables loaded with an SRID for instance EPSG:31254 are not
shown in the list of possible datasources if the
SRID is not already a valid record in the spatial_ref_sys table of
PostGIS.
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100309/aadd3a6e/attachment-0001.html
Message: 6
Date: Tue, 9 Mar 2010 08:51:42 -0800
Subject: RE: [fdo-users] AutoCAD Map 3d 2010 FDO PostGIS 3.4.1 feature
Message-ID:
    <C58680A9E35DCE45A8F1A3CA451C4DA33D4C5E3942 at ADSK-NAMSG-01.MGDADSK.autodesk.com>
Hi Karl,
You may wish to download Map 2011 and try the new FDO 3.5.0 RC1 PostgreSQL provider. Development of the PostGIS provider is somewhat frozen now that the PostgreSQL provider has been added to 3.5.0.
I know there have been several issues raised in the past with schema editing in PostGIS. I would be interested to see if these issues (and yours) are resolved in the PostgreSQL provider.
Greg
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hermann Karl
Sent: Tuesday, March 09, 2010 7:19 AM
Subject: [fdo-users] AutoCAD Map 3d 2010 FDO PostGIS 3.4.1 feature class tables are not listed
Dear List,
If you connect to a PostGIS database from AutoCAD Map 3d 2010 with FDO PostGIS 3.4.1
Feature Class Tables loaded with an SRID for instance EPSG:31254 are not shown in the list of possible datasources if the
SRID is not already a valid record in the spatial_ref_sys table of PostGIS.
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100309/61f5cfa0/attachment-0001.html
End of fdo-users Digest, Vol 39, Issue 5
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100309/16c0d4c6/attachment.html
More information about the fdo-users mailing list
