[fdo-users] Re: KingOra Cannot Find Primary Key with Some
Database Roles
Haris Kurtagic
haris at sl-king.com
Wed Mar 10 07:56:45 EST 2010
Good idea, that is workaround in such case.
If you use OracleSchema property then you will get only tables/classes which
are owned by 'OracleSchema' in each featuresource.
Still, I need to change provider. I believe it is simple change, it will
take more time to create unittest for that.
Haris
On Wed, Mar 10, 2010 at 9:27 AM, Crispin_at_1Spatial <
crispin.hoult at 1spatial.com> wrote:
> Hi - that is exactly my scenario...
> A single Oracle has been created that has access to many tables from
> different users.
> If I create multiple KineOra featuresources each with the 'OracleSchema'
> set.
> That may give me a workaround -- but will all the individual classes be
> listed under each connection or should the 'OracleSchema' filter the list?
> http://n2.nabble.com/KingOra-Cannot-Find-Primary-Key-with-Some-Database-Roles-tp4625565p4707643.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100310/b9c5e341/attachment.html
More information about the fdo-users
