[fdo-users] RE: Mysql provider can not be built
Greg Boone
greg.boone at autodesk.com
Mon May 3 18:14:18 EDT 2010
If looks as if MySQL is using a different version of Libz. You will have to adjust your MySQL build settings to account for this or install only the MySQL developer components and build from those files.
Otherwise, you may wish to do some more searching on MySQL and use of libz. Googline the issue indicates that this is a common issue for users trying to build components against a locally built version of MySQL.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of swap
Sent: Monday, May 03, 2010 5:46 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: Mysql provider can not be built
I built MySql using rpm packages.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mysql-provider-can-not-be-built-tp4991252p5000352.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
