[fdo-users] Autocad map 3D 2009, bulk copy
meryem el boukhari
meryem.elboukhari at gmail.com
Tue May 4 06:09:39 EDT 2010
Hi karl,
I fixed the problem it was a constraint violated in postgis database so i
dropped to insert data and added after, but while this procedure autocad map
3D 2009 crashed with this error:"Unhandled c 0000409h exception at
2453a016h", pls if you have an idea
Sorry for the disturbance and thank you so much
2010/5/4 meryem el boukhari <meryem.elboukhari at gmail.com>
> Hi Karl,
> Sorry for the disturbance, thank you for your answer.
> In the logfile from postgresql i got this error: "new row for relation
> "test" violates check constraint "enforce_geotype_geom_test""
> If you have any idea thank you very much.
> Meryem
> 2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
>> Hi Meryem,
>> With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
>> http://www.geomapgis.com/web/geomap-group/fdo/index.html
>> in the LogFile from PostgreSQL you can see whats going on
>> Karl
>> *Von:* fdo-users-bounces at lists.osgeo.org [mailto:
>> fdo-users-bounces at lists.osgeo.org] *Im Auftrag von *meryem el boukhari
>> *Gesendet:* Dienstag, 04. Mai 2010 10:54
>> *An:* FDO Users Mail List
>> *Betreff:* Re: [fdo-users] Autocad map 3D 2009, bulk copy
>> Hi Karl,
>> I have tried what you have said but it doesn't work, i got the same
>> message. I really don't khow why i still have this problem.
>> I tried with privileges in the postgis database and it doesn't work
>> neither.
>> Pls can you help me, i don't khow what to do and i am very pressed
>> thx very much
>>> Hy Meryem,
>>> look at this link may be it will help
>>> http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
>>> Karl
>>> *Gesendet:* Montag, 03. Mai 2010 17:47
>>> *An:* fdo-users at lists.osgeo.org
>>> *Betreff:* [fdo-users] Autocad map 3D 2009, bulk copy
>>> Hi every body, i am new user to this mailing list and i want someone
>>> to help me please it's a little bit urgent
>>> So i want to insert data from shapefile (ESRI) to my database in postgis
>>> 1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
>>> "Attempted to read or write protected memory.This is often an indication
>>> that other memory is corrupt".I granted all necesseray privileges to the
>>> user but still the same problem.
>>> Pls help me and thank you so much.
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/cb737732/attachment.html
More information about the fdo-users
