[fdo-users] Autocad map 3D 2009, bulk copy
meryem el boukhari
meryem.elboukhari at gmail.com
Tue May 4 06:45:06 EDT 2010
when i cheked i have some feautures have not copied
2010/5/4 meryem el boukhari <meryem.elboukhari at gmail.com>
> Hi Karl,
> Thank you very much for your help
> It works and i can insert data to the table in postgis, althow at the end i
> got the same message"Attempted to read or write protected memory" but When i
> check in postgis i have the values inserted and i can visualised data in
> Autocad map 3D 2009.
> I guess it's not a problem
> Meryem
> 2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
>> Hi Meryem,
>> look at this link
>> http://lists.osgeo.org/pipermail/fdo-users/2009-July/001736.html
>> compare AddGeometryColumn in Case 1 (MULTIPOLYGON) with AddGeometryColumn
>> Case 3 (GEOMETRY)
>> Karl
>> *Von:* fdo-users-bounces at lists.osgeo.org [mailto:
>> fdo-users-bounces at lists.osgeo.org] *Im Auftrag von *meryem el boukhari
>> *Gesendet:* Dienstag, 04. Mai 2010 11:39
>> *An:* FDO Users Mail List
>> *Betreff:* Re: [fdo-users] Autocad map 3D 2009, bulk copy
>> Hi Karl,
>> Sorry for the disturbance, thank you for your answer.
>> In the logfile from postgresql i got this error: "new row for relation
>> "test" violates check constraint "enforce_geotype_geom_test""
>> If you have any idea thank you very much.
>> Meryem
>>> Hi Meryem,
>>> With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
>>> http://www.geomapgis.com/web/geomap-group/fdo/index.html
>>> in the LogFile from PostgreSQL you can see whats going on
>>> Karl
>>> *Gesendet:* Dienstag, 04. Mai 2010 10:54
>>> Hi Karl,
>>> I have tried what you have said but it doesn't work, i got the same
>>> message. I really don't khow why i still have this problem.
>>> I tried with privileges in the postgis database and it doesn't work
>>> neither.
>>> Pls can you help me, i don't khow what to do and i am very pressed
>>> thx very much
>>>> Hy Meryem,
>>>> look at this link may be it will help
>>>> http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
>>>> Karl
>>>> *Gesendet:* Montag, 03. Mai 2010 17:47
>>>> *An:* fdo-users at lists.osgeo.org
>>>> *Betreff:* [fdo-users] Autocad map 3D 2009, bulk copy
>>>> Hi every body, i am new user to this mailing list and i want someone
>>>> to help me please it's a little bit urgent
>>>> So i want to insert data from shapefile (ESRI) to my database in postgis
>>>> 1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
>>>> "Attempted to read or write protected memory.This is often an indication
>>>> that other memory is corrupt".I granted all necesseray privileges to the
>>>> user but still the same problem.
>>>> Pls help me and thank you so much.
>>>> _______________________________________________
>>>> fdo-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/75c3a11d/attachment-0001.html
More information about the fdo-users
