[fdo-users] Re: arcsde connection
Orest Halustchak
orest.halustchak at autodesk.com
Tue May 4 08:37:57 EDT 2010
Hi Brad,
For direct connect to SQL 2008, set the server name for the server running SQL 2008 and use an instance name of:
sde:sqlserver:<servername>\instancename
Note that for direct connect, you need the sde direct connect libraries. Put the following dll's into your fdo bin directory (assuming that you are using sde 9.3):
gsrvrsql93.dll , sdesqlsrvr93.dll , xerces-c_2_7.dll , icuuc22.dll , and icudt22l.dll
Thanks,
Orest.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Tuesday, May 04, 2010 3:48 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: arcsde connection
Brad,
Have you seen the help here which provides the connection syntax for the
ESRI direct SDK connection?
http://trac.osgeo.org/fdo/wiki/FdoArcSDEDirectConnect
As far as the non-SDK provider (arguably poorly named with "Direct" in the
name) it only connects to SDE stores in Oracle. See
http://trac.osgeo.org/fdo/wiki/FDORfc42 for details though the algorithms
and logic would be transportable to the SQLServer provider if funded.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/arcsde-connection-tp5000154p5002138.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
