[fdo-users] AutoCAD Map 3d 2011 FDO 3.5.0 BulkCopy Point from
ShpFile to PostGIS 1.5.5 Table Coordinate Transformation Problem
Brent Robinson
brent.robinson at autodesk.com
Wed May 19 10:21:19 EDT 2010
Hi Karl,
I get the same results with this coordinate system when bulk copying to the PostgreSQL provider. The x and y values get switched. I'll do a bit more investigation to narrow down the cause.
Brent.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hermann Karl
Sent: Tuesday, May 18, 2010 5:54 AM
To: FDO Users Mail List
Subject: [fdo-users] AutoCAD Map 3d 2011 FDO 3.5.0 BulkCopy Point from ShpFile to PostGIS 1.5.5 Table Coordinate Transformation Problem
Dear List,
If I try to BulkCopy a point from a FDO_Connected shapefile to which i have allocated the coordinatesystem "MGI-AT.AUT-West / GK" (MGI / Austria GK West Zone) (srid = 31254) in AutoCAD Map 3d to a FDO_Connected point table in postgis (srid of the_geom = 31254) to which i have allocated the coordinatesystem "MGI-AT.AUT-West / GK" in AutoCAD Map 3d too, then the resulting x value of the point in the postgis table equals the y value of the original point in the shapefile and the resulting y value of the point in the postgis table equals the x value of the original point in the shapefile.
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100519/1f1ec7a9/attachment-0001.html
More information about the fdo-users
