[fdo-users] ArcSDE personal connect
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed May 26 14:07:47 EDT 2010
Here I found a few details about how to specify parameters to use direct connect, I hope it will help you.
http://www.fmepedia.com/index.php/Direct_Connect_for_SDE
Romy.
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom [kidsmake6 at msn.com]
Sent: Friday, May 21, 2010 9:26 AM
To: FDO Users Mail List
Subject: [fdo-users] ArcSDE personal connect
I have been trying to make an autocad map (2010, 2011) connection to sql2008 express with an arcsde 9.3.1 personal gdb. I get several reactions depending on which connection and the values I use. I tried going through autodesk support to get a resolution. I got the following response from them. I have seen some responses on this forum expressing that the connection is possible. Any help would be appreciated.
Brad
My connection parameters...
sql server spatial
service name: sde:sqlsserver:myserver\sqlexpress
response: credentials are not valid or provider is unable to establish a connection.
ArcSDE connection
server name: myserver\sqlexpress
instance name: sde:myserver\sqlexpress
response: no error on credentials but the data store not populated
the sde:sqlserver:myserver\SQLEXPRESS syntax works in FME and returns the geometry correctly
Autodesk Response ...
Here's the official word from the product manager:
This is not a supported configuration. Not tested. I suspect the "local connect" string is not understood by our provider. But even if Map 3D did connect, you wouldn’t be able to "create a datastore". FDO Provider for ArcSDE doesn’t allow creation of data store from Map 3D. you can only connect and edit existing ArcSDE Data Stores.
More information about the fdo-users
