[fdo-users] RE: Use of ArcSDE SDK Direct
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Thu Nov 18 14:31:20 EST 2010
Thanks Orest,
I was thrown by the Wiki page that implies you *just* need 2 DLLs - that
needs an update.
So eventually I had the Arc 9.3 SP1 Oracle client installed that set-up the
SDEHOME variable and should have all the files you reference below ... but
I'll check.
Maybe I should add the SDEHOME install to the path.
I'll update this thread once I know more information.
Thanks - Crispin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Use-of-ArcSDE-SDK-Direct-tp5751663p5752996.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
