[fdo-users] FDO VC 2008 - Compilation Issue
Elavazhagan. M
elavazhagan.mouniandy at kcubeconsulting.com
Mon Nov 22 00:48:20 EST 2010
Hello Romy,
Yes, I do have ActivePerl installed to C:\Perl. Also, I am following only
OpenSourceBuild__README.txt to build FDO.
Do you have any other clue?
Thanks,
Ela.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
> Sent: Friday, November 19, 2010 9:42 PM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] FDO VC 2008 - Compilation Issue
> Hello Ela,
> Could you please tell me if you have installed ActiveState Perl,
> available from http://www.activestate.com/ActivePerl ?
> Build steps can be found in OpenSourceBuild__README.txt
> Regards,
> Romy.
> ________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-
> bounces at lists.osgeo.org] on behalf of Elavazhagan. M
> [elavazhagan.mouniandy at kcubeconsulting.com]
> Sent: Friday, November 19, 2010 10:33 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO VC 2008 - Compilation Issue
> Hello List,
> I am trying to build FDO and Providers using VC 2008. I was able to
> compile third_party DLLs. But after that when I compile fdo using
> build.bat I am getting the following error:
> error PRJ0019: A tool returned an error code from "Performing Custom
> Build Step: Creating GRFPMessage.h and RFPMessage.rc from
> GRFPMessage.mc"
> Please not that I have already tried vcvars32.bat and vsvars32.bat with
> no success.
> Detailed output from the command prompt:
> C:\Test\fdo\OpenSource_FDO>build
> Build release Fdo dlls
> Build started 11/19/2010 8:53:41 PM.
> Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" on node 0 (Build
> target(s)).
> Building solution configuration "release|Win32".
> Message:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Message.tmp_Release_W
> in32.vcproj".
> Common:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Common.tmp_Release_Wi
> n32.vcproj".
> Geometry:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Geometry.tmp_Release_
> Win32.vcproj".
> MgCommon:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgCommon.tmp_Re
> lease_Win32.vcproj".
> Spatial:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Spatial.tmp_Release_W
> in32.vcproj".
> MgGeometry:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgGeometry.tmp_
> Release_Win32.vcproj".
> Fdo:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Fdo.tmp_Release_Win32
> .vcproj".
> MgFDO:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgFDO.tmp_Relea
> se_Win32.vcproj".
> MgSpatial:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgSpatial.tmp_R
> UnitTest:
> Deleting file
> "C:\Test\fdo\OpenSource_FDO\Fdo\UnitTest\UnitTest.tmp_Release_W
> in32.vcproj".
> Done Building Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" (Build
> target(s)
> Build succeeded.
> Time Elapsed 00:02:39.75
> End FDO Build
> Build release GdalFile provider dlls
> Microsoft (R) Windows Script Host Version 5.6
> Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
> Build started 11/19/2010 8:56:24 PM.
> Project "C:\Test\fdo\OpenSource_FDO\Providers\GDAL\Src\RFP_temp.sln" on
> node 0
> (Build target(s)).
> Project : error PRJ0019: A tool returned an error code from "Performing
> Custom
> GRFPMessage.mc"
> ln" (Build target(s)) -- FAILED.
> Build FAILED.
> Time Elapsed 00:00:01.93
> There was a build error executing action: Build
> There was a build error.
> Any help? Thanks in advance.
> Regards,
> Ela.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
