[fdo-users] FDO VC 2008 - Compilation Issue - Resolution
Elavazhagan. M
elavazhagan.mouniandy at kcubeconsulting.com
Tue Nov 23 07:32:28 EST 2010
Hi Romy,
Thanks for your help. Your workaround has helped me to figure out the actual
issue. When I was trying to run "mc" command, I found that the
"PlatformSDK\Bin" path was not added to the PATH system variable. When I
added it, everything got compiled well.
Regards,
Ela.
> -----Original Message-----
> From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
> Sent: Monday, November 22, 2010 10:48 PM
> To: FDO Users Mail List; 'Elavazhagan. M'
> Subject: RE: [fdo-users] FDO VC 2008 - Compilation Issue
> Hi Ela,
> FdoMessage.h is a generated file and it gets genetated into
> "Your_FDO_path\Fdo\Unmanaged\Inc\FdoMessage.h" by project
> "Your_FDO_path\Fdo\Unmanaged\Src\Message.vcproj"
> Below is the command line executed by the project. You can run yourself
> line by line from the command line where you set FDO variables. In case
> you get an error you can see the details about it. After running all
> below commands you should see FdoMessage.h in specified location.
> CD "Your_FDO_path\Fdo\Unmanaged"
> mc -U -h Inc\ -r Src\Message\ Src/Message/FDOMessage.mc
> ren Src\Message\FDOMessage.rc MessageDynamic.rc
> copy Src\Message\MessageStatic.rc+Src\Message\MessageDynamic.rc
> Src\Message\Message.rc
> del Src\Message\MessageDynamic.rc
> ren Inc\FDOMessage.h FdoMessage.h
> Regards,
> Romy.
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-
> bounces at lists.osgeo.org] on behalf of Elavazhagan. M
> [elavazhagan.mouniandy at kcubeconsulting.com]
> Sent: Monday, November 22, 2010 11:42 AM
> To: 'Elavazhagan. M'; 'FDO Users Mail List'
> Hello Romy,
> Here are some more supplementary information. When I try to build the
> shp
> provider alone, I am getting the below error. (I was trying in another
> machine, that is the reason for the change of the source directory)
> C:\OpenSource>build -w=shp
> Build release SHP provider dlls
> Build started 11/22/2010 10:18:37 PM.
> Project "C:\OpenSource\Providers\SHP\Src\SHP_temp.sln" on node 0 (Build
> target(
> s)).
> Building solution configuration "release|Win32".
> C:\OpenSource\Fdo\Unmanaged\inc\Common/Exception.h(26): fatal error
> C1083:
> Cann
> ot open include file: 'FdoMessage.h': No such file or directory
> C1083:
> Cann
> Done Building Project "C:\OpenSource\Providers\SHP\Src\SHP_temp.sln"
> (Build
> tar
> get(s)) -- FAILED.
> Build FAILED.
> Time Elapsed 00:00:10.31
> There was a build error executing action: Build
> There was a build error.
> Any help?
> Thanks,
> Ela.
> > From: Elavazhagan. M
> [mailto:elavazhagan.mouniandy at kcubeconsulting.com]
> > Sent: Monday, November 22, 2010 11:18 AM
> > To: 'FDO Users Mail List'
> > Hello Romy,
> > Yes, I do have ActivePerl installed to C:\Perl. Also, I am following
> > only OpenSourceBuild__README.txt to build FDO.
> > Do you have any other clue?
> > Thanks,
> > Ela.
> > > From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> > > bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
> > > Sent: Friday, November 19, 2010 9:42 PM
> > > Hello Ela,
> > > Could you please tell me if you have installed ActiveState Perl,
> > > available from http://www.activestate.com/ActivePerl ?
> > > Build steps can be found in OpenSourceBuild__README.txt
> > > Regards,
> > > Romy.
> > > Sent: Friday, November 19, 2010 10:33 AM
> > > To: fdo-users at lists.osgeo.org
> > > Subject: [fdo-users] FDO VC 2008 - Compilation Issue
> > > Hello List,
> > > I am trying to build FDO and Providers using VC 2008. I was able to
> > > compile third_party DLLs. But after that when I compile fdo using
> > > build.bat I am getting the following error:
> > > error PRJ0019: A tool returned an error code from "Performing
> Custom
> > > Build Step: Creating GRFPMessage.h and RFPMessage.rc from
> > > GRFPMessage.mc"
> > > Please not that I have already tried vcvars32.bat and vsvars32.bat
> > with
> > > no success.
> > > Detailed output from the command prompt:
> > > C:\Test\fdo\OpenSource_FDO>build
> > > Build release Fdo dlls
> > > Build started 11/19/2010 8:53:41 PM.
> > > Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" on node 0 (Build
> > > target(s)).
> > > Message:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Message.tmp_Release_W
> > > in32.vcproj".
> > > Common:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Common.tmp_Release_Wi
> > > n32.vcproj".
> > > Geometry:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Geometry.tmp_Release_
> > > Win32.vcproj".
> > > MgCommon:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgCommon.tmp_Re
> > > lease_Win32.vcproj".
> > > Spatial:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Spatial.tmp_Release_W
> > > in32.vcproj".
> > > MgGeometry:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgGeometry.tmp_
> > > Release_Win32.vcproj".
> > > Fdo:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Fdo.tmp_Release_Win32
> > > .vcproj".
> > > MgFDO:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgFDO.tmp_Relea
> > > se_Win32.vcproj".
> > > MgSpatial:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgSpatial.tmp_R
> > > UnitTest:
> > > Deleting file
> > > "C:\Test\fdo\OpenSource_FDO\Fdo\UnitTest\UnitTest.tmp_Release_W
> > > in32.vcproj".
> > > Done Building Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln"
> (Build
> > > target(s)
> > > Build succeeded.
> > > Time Elapsed 00:02:39.75
> > > End FDO Build
> > > Build release GdalFile provider dlls
> > > Microsoft (R) Windows Script Host Version 5.6
> > > Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
> > > Build started 11/19/2010 8:56:24 PM.
> > > Project
> "C:\Test\fdo\OpenSource_FDO\Providers\GDAL\Src\RFP_temp.sln"
> > on
> > > node 0
> > > (Build target(s)).
> > > Project : error PRJ0019: A tool returned an error code from
> > "Performing
> > > Custom
> > > GRFPMessage.mc"
> > > ln" (Build target(s)) -- FAILED.
> > > Build FAILED.
> > > Time Elapsed 00:00:01.93
> > > Any help? Thanks in advance.
> > > Regards,
> > > Ela.
> > > _______________________________________________
> > > fdo-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://lists.osgeo.org/mailman/listinfo/fdo-users=
More information about the fdo-users
