[fdo-users] Storing MultiCurvePolygon King Oracle Provider
Simon Pelicon
simon at sl-king.com
Thu Nov 25 07:06:24 EST 2010
Hi!
This error means that not all geometries have the same dimension or object
dimensions do not match the dimension in USER_SDO_GEOM_METADATA.
Check the MDSYS.USER_SDO_GEOM_METADATA table if metadata for your TABLE
match the stored geometry dimensionality.
Simon
On Thu, Nov 25, 2010 at 12:06 PM, GISkit_Paul <paul at giskit.nl> wrote:
> Hello,
> I try to store the different fdoGeometryTypes in Oracle. Almost all types
> are stored except the MultiCurvePolygons with as well as without
> interiorrings. I get the following exception:
> OSGeo.FDO.Common.Exception: ORA-29875: failed in the execution of the
> ODCIINDEXINSERT routine
> ORA-13364: layer dimensionality does not match geometry dimensions
> ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 623
> ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 227
> at OSGeo.FDO.Commands.Feature.IInsertImp.Execute()
> Multipolygons (i.e. without curves) using a similar functionality are
> stored
> correctly.
> I am using version 3.4 of the King Oracle Provider
> (FdoKingOracle_Win32_FDO_3_4_v0_8_26).
> Any ideas of what might be the problem?
> Regards,
> Paul
> http://osgeo-org.1803224.n2.nabble.com/Storing-MultiCurvePolygon-King-Oracle-Provider-tp5773817p5773817.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101125/02d38738/attachment.html
More information about the fdo-users
