[fdo-users] RE: Right way of creating a GML file?
Elavazhagan. M
elavazhagan.mouniandy at kcubeconsulting.com
Fri Nov 26 09:01:39 EST 2010
Okay, I somehow have got it to work. Here is a solution (still not sure if
this the correct approach, but it works!!!)
//Create an XSD file before writing the GML file - this will be used to set
XmlFeatureFlags
String xsdFilePath = gmlFilePath + ".xsd";
XmlWriter xsdXmlWriter = new XmlWriter(xsdFilePath);
XmlSpatialContextWriter spatialContextWriter = new
XmlSpatialContextWriter(xsdXmlWriter);
XmlSpatialContextSerializer.XmlSerialize(connection,
spatialContextWriter);
featureClass.FeatureSchema.WriteXml(xsdXmlWriter);
xsdXmlWriter.Close();
xsdXmlWriter.Dispose();
//Prepare to write GML file
XmlFeatureFlags xmlFeatureFlags = new
XmlFeatureFlags(xsdFilePath);
XmlWriter gmlXmlWriter = new XmlWriter(gmlFilePath);
XmlFeatureWriter xmlFeatureWriter = new
XmlFeatureWriter(gmlXmlWriter);
//Select & write the features into GML file
ISelect select =
(ISelect)connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType
_Select);
select.SetFeatureClassName(featureClass.Name);
IFeatureReader featureReader = select.Execute();
XmlFeatureSerializer.XmlSerialize(featureReader,
xmlFeatureWriter, xmlFeatureFlags);
Now, the GML is written in the correct format and QGIS is able to open it
too.
Regards,
Ela.
From: Elavazhagan. M [mailto:elavazhagan.mouniandy at kcubeconsulting.com]
Sent: Friday, November 26, 2010 4:23 PM
To: 'FDO Users Mail List'
Subject: Right way of creating a GML file?
Can somebody please tell me whether the following approach (in C#) is the
right way to generate a GML file?
//Select features
ISelect select =
_Select);
select.SetFeatureClassName(featureClassName);
//Write features
XmlWriter xmlWriter = new XmlWriter(gmlFilePath);
XmlFeatureWriter(xmlWriter);
xmlFeatureWriter);
This creates a GML file in the following format:
<?xml version="1.0" encoding="UTF-8" ?>
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds">
<building>
<gid>10</gid>
<AREA>2365</AREA>
<PERIMETER>3400</PERIMETER>
<the_geom>
<gml:Polygon srsName="EPSG:4326">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>1550000.000000,6425000.000000
1525000.000000,6425000.000000 1525000.000000,6450000.000000
1550000.000000,6450000.000000
1550000.000000,6425000.000000</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</the_geom>
</building>
</fdo:DataStore>
But I am unable to open the GML in QGIS as it says, "building.gml is not a
valid or recognized data source".
Thanks,
Ela.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101126/39280a5d/attachment-0001.html
More information about the fdo-users
