[fdo-users] RE: How to boost ISelect and IUpdate command performance
Martin Morrison martin.morrison at edsi.com
Tue Nov 30 15:17:09 EST 2010
This is the basics, but you have created an index on the field where the parameter is haven't you?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ray
Sent: Tuesday, November 30, 2010 3:15 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: How to boost ISelect and IUpdate command performance
I tried both Romy and Traian's solution.
Romy's solution doesn't work. The SelectCmd.ParameterValues returns me
nothing and it is read only. I guess autodesk fdo for Oracle doesn't support
this.
Taian's solution works. However, it doesn't have any performance gain. It
has exactly the same performace as the filter string is bound to selectCmd
in every call.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-boost-ISelect-and-IUpdate-command-performance-tp5788379p5789506.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
