[fdo-users] IApplySchema using King Oracle provider with BLOB field
GISkit_Paul
paul at giskit.nl
Wed Oct 27 07:43:43 EDT 2010
Hello,
I am trying to apply a schema in Oracle using de King Oracle Provider for
FDO. My schema consists of one field with the datatype BLOB, which I want to
use to store attributedata as a byte-array.
I get an exception at the 'Execute' method for IApplySchema stating:
'Exception: OSGeo.FDO.Common.Exception OSGeo.FDO.Common.Exception:
c_KgOraApplySchema::Execute: Unkown Property Definition at
OSGeo.FDO.Commands.Schema.IApplySchemaImp.Execute()'
When I leave out the BLOB-field it works fine. Also, if I manually add a
BLOB-field to the created table, I can store BLOB data using the same
provider. Has anyone an idea what is going wrong?
Regards,
Paul
View this message in context: http://osgeo-org.1803224.n2.nabble.com/IApplySchema-using-King-Oracle-provider-with-BLOB-field-tp5678225p5678225.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
