[fdo-users] SDF spatial index error
Steve Stanton
sstanton at btinternet.com
Wed Feb 9 17:41:35 EST 2011
Hi Romy,
It works fine on export to SQLite. I also went into FDO Toolbox and tried to bulk copy the SQLite file to SDF, and that works too.
Steve
--- On Tue, 8/2/11, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
> From: Romica Dascalescu <Romica.Dascalescu at autodesk.com>
> Subject: RE: [fdo-users] SDF spatial index error
> To: "FDO Users Mail List" <fdo-users at lists.osgeo.org>
> Date: Tuesday, 8 February, 2011, 23:38
> What's happening when you export same
> data to SQLite?
> Romy.
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org
> [fdo-users-bounces at lists.osgeo.org]
> on behalf of Steve Stanton [sstanton at btinternet.com]
> Sent: Tuesday, February 08, 2011 6:29 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] SDF spatial index error
> I'm new to FDO, trying to export some simple polygons to
> SDF (using the recent FDO 3.6 that's bundled with FDO
> Toolbox 1.0b4).
> Everything seems to be proceeding swimmingly, then it just
> fails with an exception that says "SDF spatial index error".
> It appears to be running out of some resource, since the
> polygon where the failure occurs is different each time I
> try it.
> It looks like the same problem has been logged as ticket
> #364 (see http://lists.osgeo.org/pipermail/fdo-trac/2008-July/001177.html),
> but it seems to have fallen off the radar. Which suggests I
> must be doing something a bit wrong.
> I'm currently creating a new IInsert command for each
> polygon (I realize there are some bulk processing options,
> but I thought I'd try to keep it simple). So my next step
> will be to check whether bulk processing will side-step the
> issue. My concern is whether that too might hit some
> resource utilization issue down the road.
> Any insights?
> Steve
More information about the fdo-users
