[fdo-users] Is CurvePolygon implemented?
Steve Stanton
sstanton at btinternet.com
Fri Feb 11 19:20:07 EST 2011
I'm trying to export some cadastral polygons to SDF, and quite a few of them contain circular arcs. I initially approximated these arcs with some closely spaced points, and successfully created IPolygon objects.
Then I discovered ICurvePolygon, which would let me export the arcs without any approximation. But when I try to call FgfGeometryFactory.CreateCurvePolygon, it just comes back with a null reference exception. The stack trace:
at OSGeo.FDO.Runtime.Disposable.get_UnmanagedObject()
at OSGeo.FDO.Geometry.RingCollection.GetImpObj()
at OSGeo.FDO.Geometry.FgfGeometryFactory.CreateCurvePolygon(IRing exteriorRing, RingCollection interiorRings)
at Backsight.Editor.SdfExporter.ExportCurvePolygon(Polygon pol) in C:\Users\sstanton\Code\Backsight.Editor\SdfExporter.cs:line 182
I also tried it with the SQLite provider, and got the same. Should I take this to mean that CurvePolygon isn't supported?
Steve
More information about the fdo-users
