[fdo-users] RE: (dbgql_define_rdb) Memory Error when call
FDOCmd.Execute()
Ray
ray.wu at efacec.com
Wed Feb 23 10:04:08 EST 2011
I am running an independent FDO application and I am using Window XP OS.
The thing puzzles me is that only the fdoSelectCmd.execute() has the
problem. If I put a breakpoint there and skip the exception. Other code
including .NET code, Oracle command code works fine. Even other fdo code
still works fine, like I can create new fdo InsertCmd, run
insertCmd.execute(), and fdoInsertCmd succeeded in inserting records to
database. I can also create new fdoSelectCmd, but just
fdoSelectCmd.Execute() throws the memory error.
Any special memory requirement for fdoselectcmd.execute()?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/dbgql-define-rdb-Memory-Error-when-call-FDOCmd-Execute-tp6054318p6056618.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
