[fdo-users] Re: OSM shape file limitations using with FDO due
to : in column names
Greg Boone
greg.boone at autodesk.com
Thu Jan 13 11:56:12 EST 2011
The following change sets illustrate the changes made in the SHP provider to allow DBF files that have columns containing ":" and "." to be read and processed by FDO
http://trac.osgeo.org/fdo/changeset/5858
http://trac.osgeo.org/fdo/changeset/5859
If ":" or "." are found, these characters are replaced by "_" when the DBF Physical schema is read and exposed as logical FDO Schema. Thus columns that are physically defined as a:b will be exposed logically as a_b.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
Sent: Thursday, January 13, 2011 11:36 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] Re: OSM shape file limitations using with FDO due to : in column names
On 11-01-13 11:25 AM, Greg Boone wrote:
> This issue has been resolved:
> http://trac.osgeo.org/fdo/ticket/737
Greg,
I can't help but notice that the ticket is closed without any indication of whether the problem was reproduced, action was taken, what it was, etc. Here I assumed you referred people to the ticket so they could read the whole conversation.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
