[fdo-users] Re: OSM shape file limitations using with FDO due
to : in column names
Dan Stoica
dan.stoica at autodesk.com
Thu Jan 13 16:09:51 EST 2011
For clarification: per DBF specification ":" and "." are not illegal characters. Instead there is an FDO limitation at this time in the sense it cannot create property names containing ":" or "."
The trouble was that there are products out there able to create DBF files with columns containing ':' and the SHP provider was not able to read them.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Thursday, January 13, 2011 4:02 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] Re: OSM shape file limitations using with FDO due to : in column names
That is ESRIs implementation also. They automatically convert illegal
chars in the name to _ and also truncate field names by 2 and add
numeric. My_extralong_field_name, becomes my_ext1 subsequent
duplications are numered sequentially.
On Thu, Jan 13, 2011 at 10:56 AM, Greg Boone <greg.boone at autodesk.com> wrote:
> The following change sets illustrate the changes made in the SHP provider to allow DBF files that have columns containing ":" and "." to be read and processed by FDO
> http://trac.osgeo.org/fdo/changeset/5858
> http://trac.osgeo.org/fdo/changeset/5859
> If ":" or "." are found, these characters are replaced by "_" when the DBF Physical schema is read and exposed as logical FDO Schema. Thus columns that are physically defined as a:b will be exposed logically as a_b.
> Greg
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
> Sent: Thursday, January 13, 2011 11:36 AM
> To: fdo-users at lists.osgeo.org
> On 11-01-13 11:25 AM, Greg Boone wrote:
>> This issue has been resolved:
>> http://trac.osgeo.org/fdo/ticket/737
> Greg,
> I can't help but notice that the ticket is closed without any indication of whether the problem was reproduced, action was taken, what it was, etc. Here I assumed you referred people to the ticket so they could read the whole conversation.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
