[fdo-users] ArcSDE provider: unit-tests crashes
Oyvind Idland oyvind.idland at gmail.com
Fri Mar 4 20:00:44 EST 2011
Dan,
I suspected it had something to do with my changes, but the trunk version
crashes aswell.
(both release and debug).
In addition, there are a bunch of memory leaks (mentioned in a previous
post). These seems
to occur at the initial stage, as the number of leaks are constant, and not
dependent on
the number of transactions etc.
As for detecting leaks, I use _CrtSetDbgFlag().
I don't really have much time to clean this up right now, so I would
appreciate if anybody
could look into this.
Oyvind
On Sat, Mar 5, 2011 at 1:09 AM, Dan Stoica <dan.stoica at autodesk.com> wrote:
>  Oyvind, does it crash with or without your changes? Or both?
> Dan.
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Greg Boone
> *Sent:* Friday, March 04, 2011 12:06 PM
> *To:* FDO Users Mail List
> *Subject:* RE: [fdo-users] ArcSDE provider: unit-tests crashes
> No, I can’t speak to how resent these tests may have been run from a fresh
> install of the test data.  Probably not for some time.
> Greg
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Oyvind Idland
> *Sent:* Friday, March 04, 2011 7:22 AM
> *Subject:* [fdo-users] ArcSDE provider: unit-tests crashes
> I am trying to run the unit-tests for ArcSDE, but I get a crash. I also get
> the same crash in the trunk version.
> Has these tests been run by anybody else recently ?
> For some reason, SE_uuidgenerator_free_uuids() crashes. I suspect this may
> be due to memory
> errors elsewhere, but havent got to the bottom of it so far.
> Details:
> test: BasicUpdateTests:update_uuid
> ArcSDE\Src\Provider\ArcSDEInsertCommand.cpp, line 307:
>     if (uuidColumns > 0)
>         SE_uuidgenerator_free_uuids(uuid_list, uuidColumns);
> uuidColumns = 1
> uuid_list = 0x01f7af90  "{58A06551-5F2B-4CB3-B510-D4B4D80AB21A}"
> console:
> HEAP[UnitTest.exe]: Heap block at 01F7AF88 modified at 01F7AFBC past
> requested size of 2c
> Windows has triggered a breakpoint in UnitTest.exe.
> C:\Program Files\Microsoft Visual Studio 9.0\VC\include\delayhlp.cpp
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110305/6e2fccc1/attachment.html
More information about the fdo-users mailing list
