R: [fdo-users] autocad 2011 commit changes problem
quagliamichele at tiscali.it quagliamichele at tiscali.it
Fri Mar 18 03:07:10 EDT 2011
In italiano
grazie
----Messaggio originale----
Da: vasjalebar at gmail.
com
Data: 17/03/2011 12.01
A: <fdo-users at lists.osgeo.org>
Ogg: [fdo-
I have developed an
application that synchronizes SQL tables (mssql 2008 R2)
over WCF
(using MS sync framework 2.1). This application requires triggers
(insert, update and delete) on tables one wishes to synchronize. And
this
causes a problem. If I want to commit more than one change
(insert, update
or delete) in Autocad 2011 the FDO provider (ms sql
spatial) throws this
error:
- 1= Failed to insert feature.
- 2 = RDBMS:
[Microsoft][ODBC SQL Server Driver]Neveljavno stanje kazalke.*
- 3 =
RDBMS: [Microsoft][ODBC SQL Server Driver]Neveljavno stanje kazalke.*
Feature was not processed becouse operation has been terminated
prematurely.
(2 consecutive occurrences)
* this is an error in slovene
and it means something like "Invalid state of
the cursor"
If I disable
the trigger, commit works, but if the trigger is enabled I
always get
this error (if I commit more than one change). The code behind
the
insert trigger (tried it just for this example) is:
CREATE TRIGGER
[dbo].[trg_insert]
   ON  [dbo].[oc]
   AFTER insert
AS
BEGIN
	-- SET
NOCOUNT ON added to prevent extra result sets from
	-- interfering with
SELECT statements.
	SET NOCOUNT ON;
	SELECT 1;
    -- Insert statements
for trigger here
END
The triggers I use in the application is a bit
more complicated and are a
bit to long :)
The next thing I checked
was the code of fdo provider. I found that the
provider uses
SQL_CURSOR_STATIC (in
Providers\GenericRdbms\Src\ODBCDriver\connect.c).
So my question is what if I change SQL_CURSOR_STATIC to
SQL_CURSOR_DYNAMIC?
Is this the right approach for this problem??? And
if anyone wants to know,
I HAVE TO USE TRIGGERS :)
Best regards,
Vasja
Lebar
View this message in context: http://osgeo-org.1803224.n2.
nabble.com/autocad-2011-commit-changes-problem-tp6180452p6180452.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-
users
Supera i limiti: raddoppia la velocità da 10 a 20 Mega!
Risparmia con Tutto Incluso: telefono + adsl 20 mega a soli 29,95 € al mese per due anni!
SCONTO DI 240 EURO!
http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso/?WT.mc_id=01fw
More information about the fdo-users mailing list
