[fdo-users] Memory issues when using FdoIGeometry
Snehal Joshi snehal.joshi at gmail.com
Mon Jun 4 13:41:19 PDT 2012
Hi Gavin
Thanks. I am using it in a single threaded environment.
Snehal
On Mon, Jun 4, 2012 at 3:27 PM, Gavin Cramer <gavin.cramer at autodesk.com>wrote:
>  Howdy.  Is either the geometry object or the byte array being passed
> between threads?****
> Gavin****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Snehal Joshi
> *Sent:* Monday, June 04, 2012 4:11 PM
> *To:* FDO Users Mail List
> *Subject:* [fdo-users] Memory issues when using FdoIGeometry****
> Hi All,
> I am using FDO to read feature data from ArcSDE server which has large
> number of objects. While I am able to read all the data, the memory usage
> goes up really quickly and there is no significant change even after I call
> the close() method on the feature reader.
> After some debugging it looks like the reference count for the geometry
> (as in the snippet below) doesn't go to zero even after the FdoPtr
> destructor has been called. I am pretty sure it could be something I am
> missing, will appreciate any pointers in this regard.
> FdoPtr<FdoIGeometry> geometry =
> geometryFactory->CreateGeometryFromFgf(geometryArray);
> Thanks!****
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20120604/a0571ea0/attachment.html>
More information about the fdo-users mailing list
