[fdo-users] FDO OGR <SupplementalSpatialContextInfo>
Carlos Lacerda
carlos.lacerda at gmail.com
Tue Jun 19 06:16:37 PDT 2012
Hi Guys,
I have a simple question using SupplementalSpatialContextInfo in
FeatureSource on Mapguide.
I have a Map using WGS84 SRS and need overlays with a DGN Layer in UTM23s SRS.
All right, I create a map using UTM23s and DGN Layer is rendered Ok,
but now I need use a Map with WGS84 SRS and overlays this DGN layer,
so I try use the <SupplementalSpatialContextInfo> tag in
FeatureSource definition without success, as DGN don´t have SRS inside
file I try the combinations below:
... <SupplementalSpatialContextInfo>
<Name>Corrego_Alegre_UTM_Zone_23S</Name>
<CoordinateSystem>PROJCS["Corrego_Alegre_UTM_Zone_23S",GEOGCS....</CoordinateSystem>
</SupplementalSpatialContextInfo>...
<Name>default</Name>
<CoordinateSystem>PROJCS["Corrego.UTM...</CoordinateSystem>
<Name />
<CoordinateSystem>PROJCS["Corrego.UTM-23S...</CoordinateSystem>
</SupplementalSpatialContextInfo>....
I try the same above using WGS84 on <CoordinateSystem> tag without success :(
I stay using <SupplementalSpatialContextInfo> incorrectly or OGR don´t
support this feature or I going in wrong direction ?
I have a lot of SDF files with Features in UTM23s SRS in a Map using
WGS84 SRS and the map rendering fine without need
<SupplementalSpatialContextInfo> tag.
Thanks a lot for any sugestions.
Sds,
Carlos Lacerda
System Architect - CIAS
Brasil
More information about the fdo-users
