[fdo-users] FDO OGR <SupplementalSpatialContextInfo>
Carlos Lacerda
carlos.lacerda at gmail.com
Tue Jun 19 10:37:57 PDT 2012
Thank you for your reply Jackie, it is like I think, I tryed use
<Name> empty to try capture "Default" or any SRS to force a new SRS or
convert then, now these parameters are more clear to me after you
reply.
Because this when I use a SRS UTM23 originaly of the DGN, Map is
rendered correctly but if SRS is changed on Map the same cannot
convert data from DGN to SRS of Map to render data.
Using FDO Toolbox and fdo2fdo utilities, when I create a connection
using OGR driver the spatialcontext is empty with a DGN file.
With this tests using "FDO Toolbox(FDO.3.6 drivers )" and "fdo2fdo
(FDO.3.5 drivers)" returning spatialcontext empty in both this can be
really a Bug in OGR driver.
Where can I found more info about this?!
Thanks a lot.
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-OGR-SupplementalSpatialContextInfo-tp4982399p4982475.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
