[fdo-users] FDO-provider for ArcSDE-10.0
h.klandermans h.klandermans at hawarIT.com
Wed Oct 3 03:08:06 PDT 2012
I found the answer on
http://forums.autodesk.com/t5/AutoCAD-Map-3D/FDO-ArcGIS-Provider-in-AutoCAD/td-p/3410517/page/2
To connect by FDO from AutoCad Map 2011 to ArcSDE 10.1:
AutoCad Map 3D 2011 32bit:
Using the v9.2-version of sde.dll, pe.dll and sg.dll
AutoCad Map 3D 2011 64 bit
Using the v10-version of sde.dll, pe.dll and sg.dll
Think these versions will also work on AcadMap 2012 and 2013.
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-provider-for-ArcSDE-10-0-tp4984221p5006052.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
