[fdo-users] Autocad 2012 / 2013 Direct Connection to SDE 931
Jackie Ng
jumpinjackie at gmail.com
Fri Sep 14 06:53:11 PDT 2012
Since you asked if you need those files in a 64-bit version, then the answer
is yes: you need 64-bit ArcSDE client libraries.
32-bit applications won't work with 64-bit dlls and vice versa. The bitness
must always match.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Autocad-2012-2013-Direct-Connection-to-SDE-931-tp5001863p5001940.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
