[fdo-users] AutoCAD and FDO OGR for personal geodatbases
Brad Nesom kidsmake6 at msn.com
Fri Sep 14 12:42:22 PDT 2012
That is what I found on Autodesk FDO help.
you would need to get licensing requirements from esri.
I do know that you must download the filegdb sdk and agree to the terms
there.
If I am not mistaken at 2010 all the esri writers were disabled.
now at 2012 I think you can save to esri though I have not been successful
doing that. or even getting the ogr provider activated so I could try.
brad
On Fri, Sep 14, 2012 at 12:21 PM, Bassler, Brian CTR NAVFAC MIDLANT, GIS <
brian.bassler.ctr at navy.mil> wrote:
> What is the license requirement for, to have save functionality?  Because
> I'm able to open a personal and save to dwg without said license.
> Thanks for your reply,
> Brian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Friday, September 14, 2012 13:17
> To: FDO Users Mail List
> Subject: Re: [fdo-users] AutoCAD and FDO OGR for personal geodatbases
> To connect to personal and file-based Geodatabases, you must have the
> following:
> *       A 32-bit operating system
> *       Access to Personal and File Geodatabases
> *       A valid license to either ArcGIS Desktop software or equivalent
> ArcEngine Runtime.
>         ArcEngine is included with the ArcGIS Dektop products, such as
> ArcView, ArcEditor, and ArcInfo.
> On Fri, Sep 14, 2012 at 8:30 AM, Bassler, Brian CTR NAVFAC MIDLANT, GIS <
>         Greetings,
>         I have been working with the OGR provider available for AutoCAD
> and I have a few questions.
>         First, is there a comprehensive guide to the use of the OGR
> provider?
>         I'm currently using the 3.4 version with AutoCAD Map 3D 2010.
>  I've not been able to save changes to a personal geodatabase regardless of
> the readonly setting when I connect or use of checkout/checkin from the
> ribbon.  I have found contradicting info that says features can and cannot
> be edited with this plugin.  Can I get a positive answer on this forum?
>         I'm also working with a demo version of AutoCAD Map 3D 2013.  I
> thought sure I had read somewhere that the OGR provider would be included
> in the install but it is not.  I'm not sure which version I should try, so
> far have installed the 3.7 beta but am getting connection errors which I
> believe are due to the ODBC drivers present on my test machine.  Said test
> machine is Win 7 64bit with 64bit AutoCAD 2013 and 32 bit Office 2007.
>  Note that MS Access was not included in that install so I've also
> installed the 32bit ODBC connectivity drivers from MS.  So far, this
> configuration DOES NOT work.
>         I'd like to be able to use AutoCAD Map 3D 2013 to read/edit
> features in an ESRI personal geodatabase.
>         Any recommendations? Many thanks for any help!!
>         Brian C. Bassler
>         _______________________________________________
>         fdo-users mailing list
>         fdo-users at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/fdo-users
> Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright>
> "I have a map of the United States... Actual size. It says, 'Scale: 1 mile
> = 1 mile.' I spent last summer folding it. I hardly ever unroll it. People
> ask me where I live, and I say, 'E6."
> -- Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright
[image: Steven Wright]<http://www.goodreads.com/author/show/181771.Steven_Wright>
-- Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright>
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20120914/0aa32b32/attachment.html>
More information about the fdo-users mailing list
