[fdo-users] FDO error : cannot apply schema no schema was specified
Brent Robinson
brent.robinson at autodesk.com
Thu Apr 4 04:34:05 PDT 2013
For the PostgreSQL provider, ApplySchema throws a chain of exceptions when it fails. The first one has just a general message; after that there is one exception per error in the schema. The more specific exceptions can be picked up by doing:
while (ex != NULL)
FdoString*str = ex->GetMessage();
FdoException* ex2 = ex->GetCause();
FDO_SAFE_RELEASE(ex);
ex = ex2;
Brent.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of nav
Sent: Thursday, April 04, 2013 7:20 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO error : cannot apply schema no schema was specified
While compiling the sample code present in FDODevGuide.pdf, pg 77,78,79 for creation Feature schema table in PosggreSQL, i am getting following exception Message "Schema SampleFeatureSchema has error. Cannot apply it."
Any idea what causes such an exception error?
Part of the code:
if(FdoConnectionState_Open == state)
try
// Create the ApplySchema command
FdoPtr<FdoIApplySchema> sampleApplySchema ;
sampleApplySchema = (FdoIApplySchema
*)fdoConnection->CreateCommand(FdoCommandType_ApplySchema);
// Create the feature schema
FdoPtr<FdoFeatureSchema> sampleFeatureSchema;
sampleFeatureSchema = FdoFeatureSchema::Create(L"SampleFeatureSchema",
L"Sample Feature Schema Description");
// get a pointer to the feature schema's class collection
// this object is used to add classes to the schema
FdoPtr<FdoClassCollection> sampleClassCollection;
sampleClassCollection = sampleFeatureSchema->GetClasses();
// create a feature class, i.e., a class containing a geometric
// property set some class level properties
FdoPtr<FdoFeatureClass> sampleFeatureClass;
sampleFeatureClass = FdoFeatureClass::Create(L"SampleFeatureClass",
L"Sample Feature Class Description");
sampleFeatureClass->SetIsAbstract(false);
// get a pointer to the feature class's property collection
// this pointer is used to add data and other properties to the class
FdoPtr<FdoPropertyDefinitionCollection> sampleFeatureClassProperties;
sampleFeatureClassProperties = sampleFeatureClass->GetProperties();
//FdoPtr<FdoClassCollection> sampleClassCollection2;
//sampleClassCollection2 = sampleFeatureSchema->GetClasses();
// get a pointer to the feature class's identity property collection
// this property is used to add identity properties to the feature
// class
FdoPtr<FdoDataPropertyDefinitionCollection>
sampleFeatureClassIdentityProperties;
sampleFeatureClassIdentityProperties =
sampleFeatureClass->GetIdentityProperties();
// create a data property that is of type Int32 and identifies
// the feature uniquely
FdoPtr<FdoDataPropertyDefinition> sampleIdentityDataProperty;
sampleIdentityDataProperty =
FdoDataPropertyDefinition::Create(L"SampleIdentityDataProperty", L"Sample Identity Data Property Description");
sampleIdentityDataProperty->SetDataType(FdoDataType_Int32);
sampleIdentityDataProperty->SetReadOnly(false);
sampleIdentityDataProperty->SetNullable(false);
sampleIdentityDataProperty->SetIsAutoGenerated(false);
// add the identity property to the sampleFeatureClass
sampleFeatureClassProperties->Add(sampleIdentityDataProperty);
sampleFeatureClassIdentityProperties->Add(sampleIdentityDataProperty);
// create a data property that is of type String and names the
// feature
FdoPtr<FdoDataPropertyDefinition> sampleNameDataProperty;
sampleNameDataProperty =
FdoDataPropertyDefinition::Create(L"SampleNameDataProperty", L"Sample Name Data Property Description");
sampleNameDataProperty->SetDataType(FdoDataType_String);
sampleNameDataProperty->SetLength(64);
sampleNameDataProperty->SetReadOnly(false);
sampleNameDataProperty->SetNullable(false);
sampleNameDataProperty->SetIsAutoGenerated(false);
// add the name property to the sampleFeatureClass
sampleFeatureClassProperties->Add(sampleNameDataProperty);
// create a geometric property
FdoPtr<FdoGeometricPropertyDefinition> sampleGeometricProperty;
sampleGeometricProperty =
FdoGeometricPropertyDefinition::Create(L"SampleGeometricProperty", L"Sample Geometric Property Description");
sampleGeometricProperty->SetGeometryTypes(FdoGeometricType_Surface);
sampleGeometricProperty->SetReadOnly(false);
sampleGeometricProperty->SetHasMeasure(false);
sampleGeometricProperty->SetHasElevation(false);
// add the geometric property to the sampleFeatureClass
sampleFeatureClassProperties->Add(sampleGeometricProperty);
// identify it as a geometry property
sampleFeatureClass->SetGeometryProperty(sampleGeometricProperty);
// add the feature class to the schema
sampleClassCollection->Add(sampleFeatureClass);
// point the ApplySchema command at the newly created feature
// schema and execute
sampleApplySchema->SetFeatureSchema(sampleFeatureSchema);
sampleApplySchema->Execute();
catch (FdoException *ex)
FdoString *str = ex->GetExceptionMessage();//"Schema Sample Feature Schema has error. Cannot apply it."
ex->Release();
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-error-cannot-apply-schema-no-schema-was-specified-tp5044538.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
