[fdo-users] Generating UniqueID (FdoDatatype_UniqueID )
Jackie Ng jumpinjackie at gmail.com
Sun Apr 14 23:12:49 PDT 2013
But to answer your question specifically. If you're inserting a feature into
a feature class that has an auto-generated property a value should be
generated for you, so when preparing a FDO insert command, you simply omit
setting a value for the auto-generated property.
You can inspect this new value as part of the feature reader that's returned
by FdoIInsert::Execute()
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Generating-UniqueID-FdoDatatype-UniqueID-tp5046834p5046838.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
