[fdo-users] Creating GEODB File
Jackie Ng
jumpinjackie at gmail.com
Mon Jul 22 21:07:08 PDT 2013
>>> 1. I am trying to export from Autodesk Civil3D objects with ODTable data
to SHP file - Issue is Field names are truncated.
This is a limitation of the SHP file format. Nothing can be done about it
(https://en.wikipedia.org/wiki/Shapefile#Data_storage)
>>> 2. Now is there a way I create a GEO DB using FDO.
Not that I know of. I think the ArcGIS FDO provider may be able to connect
to ESRI gdbs
(http://wikihelp.autodesk.com/AutoCAD_Map_3D/enu/2014/Help/0005-FDO_Deve0/0127-OSGeo_FD127)
not sure exactly.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Creating-GEODB-File-tp5068105p5068106.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
