Can you describe the current schema, add your desired properties to the class and then re-apply the modified schema? - Jackie -- View this message in context: http://osgeo-org.1560.x6.nabble.com/Updating-Table-dynamically-tp5062236p5062240.html Sent from the FDO Users mailing list archive at Nabble.com.
