[fdo-users] Slow FDO insert
Martin Morrison martin.morrison at edsi.com
Mon May 6 09:55:26 PDT 2013
So where are you writing the shape file to?  Network drive?  If so, try writing it local.
I presume after some of the comments you are writing chunks of data rather than one block at a time.  How large are the chunks?
What if you changed to a real database (e.g. SQL Server, Oracle, MySQL)?  Is it faster?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matteo
Sent: Monday, May 06, 2013 11:32 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] Slow FDO insert
Hi Jackie,
  I follow your instructions but I have not seen improvements. I test it with SHP files.
Have you another ideas?
Regards
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Slow-FDO-insert-tp5051522p5051664.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
