[fdo-users] How to listen for a Postgresql LISTEN?
nav
navin.pro at gmail.com
Thu May 23 04:24:32 PDT 2013
Postgresql has NOTIFY
<http://www.postgresql.org/docs/9.0/static/sql-notify.html> and LISTEN
<http://www.postgresql.org/docs/9.1/static/sql-listen.html> .
I figured out how to issue a NOTIFY command using
*FdoPtr<FdoISQLCommand> objSql;
objSql =
(FdoISQLCommand*)m_objFDOConnection->CreateCommand(FdoCommandType_SQLCommand);*
and
*FdoPtr<FdoISQLDataReader> objSqlDataReader;
objSqlDataReader = objSql->ExecuteReader();*
but once my FDO application issues a LISTEN command, how can I ensure that
when some other client issues NOTIFY, my FDO application will be able to
capture the signal received from LISTEN? Is there anything in FDO that can
specifically listen for signals from LISTEN?
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-listen-for-a-Postgresql-LISTEN-tp5055214.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
