[fdo-users] using map3d 2014 64 bit
Heddo Klandermans
h.klandermans at hawarIT.com
Thu Nov 28 03:44:15 PST 2013
Hi Brad,
I get that problem on 2013 as well...I even tried the most recent dll's
from Esri which come with ArcGIS 10.1...
Heddo
H.D. (Heddo) Klandermans
Senior Consultant
Hawar Information Technology bv
Oude Koemarkt 59b, 8601EJ Sneek
Tel.: +31 515 570333
Mob.: +31 6 15373947
E-mail: h.klandermans at HawarIT.com
Brad Nesom schreef op 27-11-2013 19:09:
> Thanks Heddo,
> I have copied the files into fdo/bin
> and previously this worked on 2013.
> now I get the following...
> Failed to connect.
> FDO Provider entry point function 'CreateConnection' returned NULL.
> I am trying a re-install now
> On Wed, Nov 27, 2013 at 3:13 AM, Heddo Klandermans
> <h.klandermans at hawarit.com> wrote:
>> Hi Brad,
>> Esri provides the 64bit-dll's needed (pe.dll, sde.dll, sg.dll) with their
>> software. Copying these files into the Acad Map 3D FDO/bin-folder served us
>> right (at least for AcadMap 2011). Have not tried this yet on AcadMap 2013
>> or 2014 however....
>> Senior Consultant
>> Brad Nesom schreef op 26-11-2013 23:35:
>>> I just read that the ArcGIS connection is only supported on 32 bit os.
>>> I have been unsuccessful connecting to sde since I have updated to 2014
>>> and 10.2
>>> I can't really find anything to help me.
>>> Can someone point me to information.
>>> Should I still use the old method of copying the sde files?
>>> Where can I find information about adding the ArcGIS connection?
>>> Does the ArcGIS connection add any datatype other than file gdb and
>>> personal gdb?
>>> All this is in reference to 64 bit
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
