[fdo-users] [Fdo2FDO]f2fcmd command line change Filter with parameter
Hans Milling
hm at geograf.dk
Mon Mar 24 13:02:04 PDT 2014
The ogr2ogr syntax is like this:
ogr2ogr -f "ESRI Shapefile" c:\temp\table.shp
OCI:username/password at Server/Xe -sql "select * from mytable where
INSEE=40042" skipfailures
I never used f2fcmd so I cannot help you with that.
Best regards
Hans Milling
Fra: fdo-users-bounces at lists.osgeo.org
[mailto:fdo-users-bounces at lists.osgeo.org] På vegne af Rémy GOURRAT
Sendt: 21. marts 2014 14:34
Til: 'fdo-users at lists.osgeo.org'
Emne: [fdo-users] [Fdo2FDO]f2fcmd command line change Filter with parameter
I use with success Fdo2Fdo to extract each night SDF from Oracle DB.
withthis command line in a batch :
f2fcmd copytask "../XML/SDF_AEP.XML"
But now I would extract with a parametric filter like INSEE=40042
Someone know a syntax to do that without rewrite the XML and the
<CopyFilter></CopyFilter> balise
Thanks
Rémy
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20140324/f836eedd/attachment.html>
More information about the fdo-users
