[fdo-users] Setup ASP.NET application to run with FDO
Gunter Becker gunter.becker at csogis.de
Wed Apr 1 04:56:16 PDT 2015
in my ASP.NET web application I would like to work with the FDO library.
When setting the path to FDO library in my environment variables then
everything is working fine.
But I would like to have my web app to work without this "hardcoded"
setting.
There where some suggestions in these posts:
http://osgeo-org.1560.x6.nabble.com/FDO-in-C-ASP-Net-Web-Application-td3900526.html
<http://osgeo-org.1560.x6.nabble.com/FDO-in-C-ASP-Net-Web-Application-td3900526.html>
http://osgeo-org.1560.x6.nabble.com/problem-with-FDO-td3899122.html
<http://osgeo-org.1560.x6.nabble.com/problem-with-FDO-td3899122.html>
But unfortunately this doesn't seem to work.
What I've done so far:
1. Copy all files from FDOs bin folder to my web applications bin folder
2. Set EnvironmentPath in Application_Start (Global.asax):
3. Set reference to the following files:
4. Testing this setup with:
When executing the first line I get this error:
I suppose that someone has already solved this problem.
So, what can I do. Any ideas!
Thanks, Gunter
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setup-ASP-NET-application-to-run-with-FDO-tp5196441.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
