[fdo-users] SpatialConditionFilter Error
VitecPer
per.bjorklund at vitec.se
Fri Oct 9 04:16:01 PDT 2015
Hello,
I've come across an issue when I am using a SpatialCondition Filter on my
SelectFeature Command towards my oracle database.
If I dont add the filter everything runs great, but when I add a
SpatailCondition I get the error message "Spatial Context '' not found ".
Here is how my code works in VB.NET
Dim connManager as OSGeo.FDO.IConnectionManager =
OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager()
Dim conn As OSGeo.FDO.Connections.IConnection =
connManager.CreateConnection("Autodesk.Oracle.3.9")
conn.ConnectionString =
"Service=Database;Username=Username;Password=Password;Datastore=Data"
conn.Open()
Dim selCmdLine As OSGeo.FDO.Commands.Feature.ISelect =
conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select)
selCmdLine.FeatureClassName = New OSGeo.FDO.Expression.Identifier("VIEW")
Dim geometryFactory As New OSGeo.FDO.Geometry.FgfGeometryFactory()
Dim polystring As String = "POLYGON ((148697.589 6585101.768, 148697.589
6585091.695, 148722.198 6585091.695, 148722.198 6585101.768, 148697.589
6585101.768))"
Dim poly As OSGeo.FDO.Geometry.IPolygon =
CType(geometryFactory.CreateGeometry(polystring),
OSGeo.FDO.Geometry.IPolygon)
Dim byteArray As Byte() = geometryFactory.GetFgf(poly)
Dim qryGeomVal As OSGeo.FDO.Expression.GeometryValue = New
OSGeo.FDO.Expression.GeometryValue(byteArray)
selCmdLine.Filter = New OSGeo.FDO.Filter.SpatialCondition("SHAPE",
OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Intersects, qryGeomVal)
Dim ftrRdr As OSGeo.FDO.Commands.Feature.IFeatureReader = selCmd.Execute()
At the selCmdline.Execute() the exception occures.
What am I doing wrong?
or How can I specify the spatial context for the command?
Thankful for any help.
// Per
View this message in context: http://osgeo-org.1560.x6.nabble.com/SpatialConditionFilter-Error-tp5228975.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
