[fdo-dev] fdo 3.1.0 on fedora core 5
Greg Boone
greg.boone at autodesk.com
Tue Aug 8 10:06:49 EDT 2006
This problem has not been fixed in the 3.1.0 release posted to the OSGeo
site. However, this issue has been addressed in 3.2.0, which is the
current version of FDO in the FDO OSGeo Subversion and subprojects.
(NOTE to use FDO 3.2.0 with MapGuide you will also have to retrieve and
build the MapGuide source from the MapGuide OSGeo Subversion)
The solution to this issue was to remove the class qualifier from class
method declarations in the offending FDO header files.
Greg
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, August 08, 2006 8:01 AM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] fdo 3.1.0 on fedora core 5
Carsten Ahlf wrote:
> Hi,
> I've tried to build fdo 3.0.0 on FC5 a few weeks ago
> and wasn't very successful. I always ran into "extra
qualification"-errors
> while compiling, and editing the source code resulted in a completed
> compilation,
> but the unit test just threw errors then.
> Yesterday, I noticed the release of fdo 3.1.0 and was hoping that
> now it would compile on my FC5-box, but once again I'm running
> into "extra qulification"-errors.
> My gcc-version is 4.1.1 20060525 (Red Hat 4.1.1-1).
> Here is the output of the errors:
Carsten,
Have you seen Marcus posts in the list archives?
You can find there explanation of this problem
https://fdo.osgeo.org/servlets/ReadMsg?list=dev&msgNo=27
and some guidance how to solve it:
https://fdo.osgeo.org/servlets/ReadMsg?list=dev&msgNo=25
https://fdo.osgeo.org/servlets/ReadMsg?list=dev&msgNo=30
https://fdo.osgeo.org/servlets/ReadMsg?list=dev&msgNo=31
Best regards
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
