Assertions
Mateusz Loskot
mateusz at loskot.net
Sat Aug 12 23:04:24 EDT 2006
What is the recommended way to set assertions in FDO code?
As I see, there are used two types of asserts in FDO code:
- assert from <cassert> header
- ASSERT macro
I suppose that ASSERT macro is re-definition of _ASSERT from Windows
and on non-Windows platforms it is defined as empty macro, file
Fdo/Unmanaged/Src/Fdo/Schema/SchemaAttributeDictionary.cpp
or
Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsDescribeSchemaCommand.cpp
Any recommendations?
FDO_CPPUNIT_ASSERT and CPPUNIT_ASSERT are only for usage in Unit
Tests, right?
Best regards
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo_dev
