[fdo-dev] [UnitTest] More detailed log
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Mon Aug 28 09:43:53 EDT 2006
Hi Mateusz,
You must fill up your MySqlInit.txt file with the right values.
The unit test stops when an exception is thrown in a test function and
there is missing a "try{}catch(...){}" block.
Regards,
Romy.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Sunday, August 27, 2006 10:28 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] [UnitTest] More detailed log
I tried to run MySQL Unit Test for the first time and it failed
with exception thrown.
I expected it, but I wonder how could I get detailed log message
with file/line/function info?
Simply, how to know what to fix here?
mloskot:~/dev/fdo/_svn/Providers/GenericRdbms/Src/UnitTest$
./UnitTestMySql
Test ID: 2031106080
.F.F.F.F.F.F.F.F.F.F.F..F.F.F.Test is in group 'rollback', skipping test
.Initializing Connection ...
terminate called after throwing an instance of 'FdoException*'
Aborted
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
