[fdo-dev] [UnitTest] More detailed log
Mateusz Loskot
mateusz at loskot.net
Mon Aug 28 11:02:01 EDT 2006
Romica Dascalescu wrote:
> Mateusz,
> UnitTestMySql is using by default MySqlInit.txt
> UnitTestOdbc is using by default OdbcInit.txt
Romica,
Yes, now it's clear.
> If you want to specify a different file name, you can do that by
> running:
> ./UnitTestMySql initfiletest=MySqlInitEx.txt
> ./UnitTestOdbc initfiletest=OdbcInitEx.txt
What do you think about adding --help parameter that will
print usage message?
For example:
./UnitTestMySql --help
Usage: UnitTestMySql [initfiletest=<custom init file>]
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo_dev
