[fdo-dev] Checking new'ed pointers for NULL
Greg Boone
greg.boone at autodesk.com
Mon Aug 28 11:42:42 EDT 2006
Why do you advocate not to test pointers for NULL before calling delete
operator?
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Monday, August 28, 2006 11:09 AM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] Checking new'ed pointers for NULL
Pierre Dalcourt wrote:
> Hi Mateusz,
> I think most of us agree with you. The code that checks for a new
> operator returning NULL is either old code or code that was written by
> developers (including myself) before they realized that the new
operator
> on modern compilers would never actually return NULL. :-) However,
> code that does the extra check is usually not harmful in itself so it
> may not be worth spending the extra effort to remove them unless you
> happen to be working on those files...
I see and I agree, though for me this redundant tests make it
harder to read and analyze the code, especially when function bodies
are >100 lines long.
So, to summary this thread:
- it's OK to to not to test pointers for NULL after allocation with new
operatir
- it's OK to not to test pointers for NULL before calling delete
operator.
If there are no objections, I'm following those rules in my code for
FDO.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
