[fdo-dev] Named tests
Mateusz Loskot mateusz at loskot.net
Sun Dec 3 08:59:40 EST 2006
Mateusz Loskot wrote:
> Hi,
> Why Common tests for FDORDBMS do not use named registration
> (CPPUNIT_TEST_SUITE_NAMED_REGISTRATION) ?
> Only MessageTest from Common tess and provider-specific tests are
> registered with names.
I've just noticed the Common tests serves as base test suites used in
specific testes.
Does it mean that executing test with name "ConnectTests",
combination of ConnectTests + MySqlConnectTests will be executed?
That's what I read in CppUnit docs of CPPUNIT_TEST_SUB_SUITE macro:
"In addition, the test suite of the parent is automatically inserted
in the test suite being defined."
http://cppunit.sourceforge.net/doc/lastest/group___writing_test_fixture.html#ga1
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo_dev mailing list
