[fdo-dev] Pre-conditions and unsafe constuctions
Traian Stanev
traian.stanev at autodesk.com
Thu Dec 7 12:31:37 EST 2006
The problem reported there looks like it's simply programmer oversight
(which happens when there are so many classes floating around). I don't
know of a blanket way to fix incorrect use of casting, apart from making
everyone program in Java or C#.
Traian
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Thursday, December 07, 2006 12:24 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] Pre-conditions and unsafe constuctions
Mateusz Loskot wrote:
> Traian Stanev wrote:
>> Hi Mateusz.
>> I think you're overthinking it. Use whatever cast will do the job
>> correctly.
> Hi Traian,
> I'm just trying to understand the rationale behind SmartCast and
> DownCast, and why errors are not reported with exception.
> I will try to ask another way:
> What should the FDO do if dynamic_cast fails?
My reasoning behind asking these questions is that I see I can expect in
FDO problem as reported here:
https://fdo.osgeo.org/servlets/Scarab?id=FDO123
So, I'm looking for good solution that will help me to catch these kind
of problems.
At best, I'd prefer to stick to "FDO way", what I'm asking for.
OK, let's forget these questions.
I'll do it as best as I can and I see what reviewers will tell about it.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
