Binary compatibility change to fdo.dll (trunk version)
Brent Robinson brent.robinson at autodesk.com
Fri Dec 15 16:05:02 EST 2006
I will be checking in some modifications to the svn trunk that will
change the binary compatibility for fdo.dll. Once this is done, if you
update from the svn trunk and build the FDO project, you will also need
to build your providers. The changes will likely go in on Monday, Dec
18.
The above does not affect the 3.2.x branch. The FDO binary compatibility
will not change for this branch.
Brent.
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061215/3df9c4e5/attachment.html
More information about the Fdo_dev mailing list
