[fdo-dev] fdo and fdocore
Fri Jul 7 12:37:50 EDT 2006
> I tried to run the UnitTest but it failed.
> Here is the last message:
> F.........................................
> UnitTestUtil.cpp:47:Assertion
> Test name: 7XmlTest.testXsl
> �p���y�p���z�p���<���(�p����l����p���C�(�p���r�z�(2
> Failures !!!
> Run: 99   Failure total: 1   Failures: 1   Errors: 0
> Note, the strange characters above, something like binary output.
> Do I need to do any configuration for the UnitTest?
> [GB] So, only 1 test failed? No setup should be required. I will retry the unit tests and see if I can reproduce.
Greg / Mateusz,
I tried UnitTest for the core api, and got:
warmerda at gdal2200[218]% ./UnitTest
In-memory limited conversion to unaligned FGF Polygons, retained as FGF...
0.023135 sec for 14915 positions in 343 polygons (14826 geom/s)
In-memory use of limited retained, unaligned FGF, accessed via streamed
geometries...
0.111158 sec for 304095 positions in 7000 streamed geometries (62973 geom/s)
............................Filter = ( Width*Length ) AS Area, Area = 123
............................ERROR (XSL Processor): 'xsl:variable' has an
invalid 'junk' attribute, at URI 's���8��8ˁƔʰ  ����' (line 1, column 225)
WARNING (XSL Processor): At source node '#document/DataSet', '' is an illegal
element name. The element will not be added, at URI 's��d�' (line 1, column 299)
OK (99)
warmerda at gdal2200[219]%
No *apparent* failures, but I don't get the same sort of summary report
that Mateusz saw.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
More information about the Fdo_dev mailing list
