FDO on Core 5
carsten at raumportal.de
Wed Jul 12 19:14:45 EDT 2006
Good evening,
I'm having the same problems with building FDO 3.0.0 on Fedora Core 5
as Marcus has.
On the mapguide mailing list, there is a workaround for the "extra qualification"-
errors Marcus gets, see this link:
https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=2063
But using this tip only leads to other "extra qualification"-errors coming up
later in the compilation process which can't be fixed that easily (at least not by me).
I'm using GCC 4.1.1.
Could there be any other problem except the compiler-version?
Greetings
Carsten Ahlf
More information about the Fdo_dev
